Building Integrity
Long Ez
Control System
Work Logs Found:
95
Category Work Time:
279 Hours
Date
Hours
Work Log Summary
Details
09-10-2019
3.00
Dangit Burt!
Details
09-09-2019
3.00
Ailerons and rudders are installed
Details
09-07-2019
3.00
Right wing hardware is in
Details
10-01-2018
Uh oh
Details
05-15-2018
4.00
New rudder cables finished and controls are in
Details
05-09-2018
All new Rudder cables
Details
03-06-2018
5.00
Topside finishing begins
Details
04-25-2017
0.50
Rudder cable adjustments
Details
02-29-2016
3.00
Bellcrank clearances
Details
02-01-2016
0.50
New Heim Bearings for the Elevator
Details
12-09-2015
6.00
Rockin and ROLLIN
Details
04-06-2015
Trim springs
Details
04-02-2015
4.00
Lets try again
Details
01-31-2015
Pitch trim springs
Details
01-29-2015
2.50
Rudder cables are done
Details
01-28-2015
Firewall pulleys and new cables
Details
01-14-2015
Cable pulleys are in!
Details
01-12-2015
5.00
Rudder cable pulley brackets
Details
01-11-2015
0.00
Something new
Details
12-21-2014
New bellcranks installed
Details
12-20-2014
The cozy girls are lost
Details
12-15-2014
Marco...POLO!
Details
11-03-2014
4.00
Making new Rudder cables
Details
09-23-2014
4.00
Rudder cable complete and AP Servo
Details
09-22-2014
8.00
Proper rigging and clearance issues
Details
09-22-2014
0.00
Details
09-21-2014
3.00
Not a bad fix, and a needed good day
Details
09-20-2014
The previous Builder needs to be jailed
Details
09-18-2014
3.00
Left wing is ready
Details
09-17-2014
0.00
Left wing adjustments and prep for heat shield 2
Details
09-17-2014
8.00
Details
09-16-2014
2.50
Right wing adjustments and left wing begins
Details
09-15-2014
0.00
Aileron torque tube, pushrods and teflon 2
Details
09-15-2014
8.00
Details
09-14-2014
4.50
Blessing and Curse
Details
09-13-2014
0.00
Pushrods and Canard install 2
Details
09-13-2014
8.00
Details
09-12-2014
0.00
Prepping the parts and helping out a buddy 2
Details
09-12-2014
6.00
Details
09-05-2014
Rudder cable springs.
Details
09-03-2014
0.00
Rudder cable fabrication begins 2
Details
09-03-2014
6.00
Details
08-29-2014
Stick grip and roll trim knob installed
Details
08-25-2014
Pilot Stick grip assembly
Details
06-07-2014
0.00
Throttle cable and console install 2
Details
06-07-2014
5.00
Details
05-25-2014
0.00
Stick Grips are done!!!!!
Details
04-15-2014
Aileron Torque tube installation
Details
04-12-2014
3.00
All grips accounted for
Details
01-06-2014
3.00
Stick grip sanding
Details
05-29-2013
0.50
Torque tube bearing install
Details
02-19-2013
Roll trim titanium is in
Details
02-15-2013
0.50
Better than expected!
Details
02-12-2013
0.00
Roll Trim rolls on 2
Details
02-12-2013
25.00
Roll Trim rolls on
Details
01-13-2013
Final Controls install
Details
12-16-2012
0.50
Rudder conduit glass reinforcements
Details
12-09-2012
3.00
Aileron torque tube routing
Details
12-08-2012
3.50
Rudder conduits
Details
11-07-2012
0.25
Final Trim wheel install. hooray!
Details
11-06-2012
5.50
Pitch trim wheel finishing
Details
11-04-2012
5.50
Pitch trim wheel installed
Details
11-03-2012
0.00
Pitch trim wheel construction 3
Details
11-03-2012
0.00
Pitch trim wheel construction 2
Details
11-03-2012
8.20
Pitch trim wheel construction 1
Details
11-01-2012
8.00
Pitch trim wheel
Details
10-28-2012
4.00
A new idea brewing
Details
10-17-2012
2.50
Roll Trim Success
Details
10-15-2012
4.00
Roll Trim woes
Details
10-07-2012
7.00
Roll Trim 95% complete
Details
10-04-2012
Roll Trim
Details
08-06-2012
1.50
Elevator pushrods
Details
08-02-2012
Fine tuning
Details
07-28-2012
Elevator connection
Details
07-25-2012
Glassing the brackets
Details
07-23-2012
Controls and consoles assembly
Details
07-22-2012
5.00
Floxing the brackets
Details
07-21-2012
5.50
Controls have arrived!
Details
06-23-2012
Stick grip lookin good
Details
06-15-2012
3.50
A new grip
Details
06-05-2012
Shaping the stick grip
Details
05-24-2012
Elevator Trim adjusted
Details
05-22-2012
Glassing the Throttle grip
Details
05-17-2012
6.00
An unsuccessful evening
Details
05-16-2012
8.50
Installing pitch trim system
Details
05-16-2012
1.50
Cutting out acces to pitch trim lever
Details
05-15-2012
1.50
Roll trim construction
Details
05-15-2012
3.50
Pitch trim glass and metal work
Details
05-15-2012
3.00
Making a custom throttle grip
Details
05-12-2012
Details
05-11-2012
Trial fit of trim system to fuselage
Details
05-10-2012
1.50
Trial assembly of elev. trim system
Details
05-10-2012
1.50
Polishing Trim lever
Details
05-10-2012
Control system brackets
Details
05-03-2012
Details
Long Ez Home
5429
Airframe Tweaking
262
Canard
226
Control System
95
279
Cowling
129
363
Electrical System
Elevators
934
Finishing
561
1584
Firewall
FLIGHT TESTING
41
Fuel system
Fuse Exterior
246
Instrument Panel
Landing Brake
Main Landing Gear
Nose and Nose gear
111
236
Plans
Scheduled Maintenanc
Seat Belts
Spar
Strakes
73
228
The Beginning
The Shop
Throttle
Weight and Balance
Winglets and Rudders
130
