The plans call for just a bead of flox to hold the rudder cable conduits to the side of the fuselage walls. I however, feel that in the event where hard, abrupt rudder movements at high speeds happen (rarely) that the flox bead "might" break loose under cable tension. Though my theory may not have any relevance, I still wouldn't want to deal with the result if it did. Therefore I added a small piece of 1 ply bid to the 4 joints where the pressure would most likely be. Hardly any added weight for a little more peace of mind. :)
