When finally getting the BL and FS lines marked I was sorely shocked how much of the passenger armrest had to be cut into in order to clear the torque tube. Of course building a ledge that angles up about 20 degrees to fix the issue but I think the problem originated when I decided to mount the control rod bearing housing up higher than plans. No worries I'll work with what I have :) I'll first mount my extrusions and engine mount before floxing the torque tube bearing in place. This will give me the opportunity to make sure I have full range of motion for the ailerons.
