Building Integrity
Date:  11-4-2012
Number of Hours:  5.50
Manual Reference:  ch 17
Brief Description:  Pitch trim wheel installed
I'm pleased to report that the trim wheel works JUST as planned! Low friction wheel with high tension on the springs to create a very easy and smooth to opperate pitch trim system. I also decided to remove the connecting hardware between the cable and springs. I felt that changing springs or cutting them to length is so simple that I'd reduce points of failure and keep things simple. A couple minor adjustments along with cutting ou the knotches on the wheel and it will be complete. VERY good weekend!
trim wheel system installed
