Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  William Johnson
  Wichita, KS - USA
Aircraft:
  Safari
Total Build Hours:
  555
Web Site:
  http://www.mykitlog.com/discap/
Date:  12-28-2015
Number of Hours:  0.00
Short Description:  Rotor Tach Sender
I have been fighting to get a stable Rotor Tach display since I started flying. I have used at least 4 certified rator tach generators. I think they must be designed for a mechanical display that dampens the signal through hysterisis or friction. With my MGL Odyssed these do not exist.
Shown is my solution. This is known as a Proximity Sensor. I don't have the part# handy but if anyone is interested I can supply it. This thing was CHEAP. I think it was $30 including the cable with preinstalled connector. the theory is that you swing a piece of iron past the end and it generates a signal. You need to swing the iron past the end of it not just under it.
I am currently using only one chunk of steel but will add another for balancing purposes one I get a chance. No moving parts. I do need to make a more elegant mount now that I know it works.
Prox Sensor for Rotor Tach
 Recent Builder Activity
Builder Project Date Hours
Adam Grosser
RV-7A
04-25
837
Jean Gosselin
RV6
04-25
2679
Peter McBain
RV-9A
04-25
2122
Bob Corriveau
RV-8
04-24
4168
Michael Smith
RV-7
04-24
696
Andrey Piskarev
Highlander
04-23
3812
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
04-23
2046
Michael Sausen
RV-10
04-22
1513
Chuck Bennett
Sonex-B Tri-Gear
04-21
1152
Johann
TSI
04-21
914
Mark Johnson
RV-10
04-20
490
Barry Wawrin
RV14A-QB
04-19
2379
Paul Minelga
Bearhawk
04-17
4222
Jim Novak
RV-8
04-14
3159
Darrel Watson
H-5
04-12
457
Peter Calley
Sling4
04-11
2305
Sven Hollenbeck
RV-8
04-08
70
Wendell Engelien
RV-6A
04-04
2354
Mark Spedding
COZY MK IV
04-01
3463
John McGlynn
S-19
03-30
346
Des Howson
Sling 2 Taildragger
03-25
3606
Marlin Sander
RV-7A
03-25
5652
Edward Beam
RV-14A
03-22
1304
Gary Smith
RV-10
03-22
2863
Jack Clark
RV-14A
03-22
604
Tony Batchelar
RV6
03-17
Alex KOLLEP
Sportsman 2+2
03-15
1656
James Chadwick
RV-7
03-14
748
JAMES TRAYNOR
VELOCITY- XLRG
03-11
2528
Andrew Duff
Nexus Mustang
03-09
2943
Projects Uploaded: 1549
Logs Uploaded: 283987
Copyright © 2001-2024 Matronics. All Rights Reserved. Privacy Policy.
