Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Wendell Engelien
  Jacksonville, FL - USA
Aircraft:
  RV-6A
Total Build Hours:
  2437
Web Site:
  http://www.mykitlog.com/WenEng/
Date:  06-13-2025
Short Description:  Install 4 mating screws btw top and bottom cowl
There have been several cleco holes drilled into this forward joining spot during the build. The final location I chose for two 8/32 flush machine screws on each side did not use most of the old holes. They will be filled when the cowl gets it final fiberglass coating and sanding before paint.
This was repeated on the other side so now when the cowl is mounted, the firewall has skybolts, the sides have hinges and the forward-most location behind the spinner gets 4 machine screws into nutplates.
 Recent Builder Activity
Builder Project Date Hours
Brad Kunkel
Zodiac CH 601 XLB
09-18
1240
Jacob Hedberg
S-21 Outbound
09-18
Mark Santangelo
DR-107
09-18
532
Jim Novak
RV-8
09-12
3723
Jack Clark
RV-14A
09-11
1576
Charles Wright
RV-8
09-06
164
JAMES TRAYNOR
VELOCITY- XLRG
09-06
2680
Darrel Watson
H-5
08-26
970
Mark Johnson
RV-10
08-22
765
Keith Borgstrom
Sonex
08-16
538
Michael Freiherr von Maltzahn
RV-12is
08-16
555
Neil Rosoff
EX-3
08-12
1190
Stephen Satava
RV-7
08-07
3102
Daniel Goudreault
FP-303
08-02
80
Des Howson
Sling 2 Taildragger
07-23
3900
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
07-22
4276
Kevin W. Bulla
Fokker Dr1
07-12
684
Peter McBain
RV-9A
06-06
2326
Mark Jackson
RV-8
05-17
1674
Robert Lussow
RV-15
04-13
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-12
Brian Robinson
Xenos
03-20
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
03-11
2234
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
James Chadwick
RV-7
02-01
1013
Robert Chopin
RV-8
01-19
930
Mark Spedding
COZY MK IV
01-14
3925
Chuck Bennett
Sonex-B Tri-Gear
01-10
1402
Randy Doughty
CH750 Cruzer
01-10
1001
Projects Uploaded: 1567
Logs Uploaded: 289068
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
