Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Mark Spedding
  Darraweit Guim, Victoria - Australia
Aircraft:
  COZY MK IV
Total Build Hours:
  3993
Web Site:
  http://www.mykitlog.com/Spodman/
Date:  09-14-2026
Number of Hours:  3.00
Short Description:  Cabin Heat T
Attempted to refit the cabin heat T, and it just does not work. It is a stupid shape and the diameter where the hoses attach is just too bit. Make a new design that will incorporate more of the required turn in the T. Grind a joggle where the halves will overlap and cover the upper half with about 3-4 x BID using small bits around the narrow bit.
Trimmy, trimmy on cure. Taped it up and 3 x BID over the bottom, overlapping the top.
On cure drilled for assembly cleco and popped both halves off the form. Glued together with urethane bond and 1 x BID tape over the joins.
And the word has just come through. Teesdale sold! Last big efforts to finish our preparations, cleaning and shifting a shed full of CRAP! Next task when the money comes through is to get organised with the electrical system.
 Recent Builder Activity
Builder Project Date Hours
Jean Gosselin
RV6
11-24
2824
Michael Freiherr von Maltzahn
RV-12is
11-24
629
Jim Novak
RV-8
11-23
3784
Brad Kunkel
Zodiac CH 601 XLB
11-21
1305
Jack Clark
RV-14A
11-19
1658
Chuck Bennett
Sonex-B Tri-Gear
11-16
1513
Mark Jackson
RV-8
11-14
1677
Jacob Hedberg
S-21 Outbound
11-12
48
Daniel Goudreault
FP-303
10-22
108
Doug Volkmer
RV-7
10-21
1251
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
10-16
2397
Charles Wright
RV-8
10-15
172
Mark Johnson
RV-10
10-02
777
Des Howson
Sling 2 Taildragger
09-25
3952
JAMES TRAYNOR
VELOCITY- XLRG
09-23
2693
James Chadwick
RV-7
09-19
1123
Mark Santangelo
DR-107
09-18
532
Mark Spedding
COZY MK IV
09-14
3993
Darrel Watson
H-5
08-26
970
Keith Borgstrom
Sonex
08-16
538
Neil Rosoff
EX-3
08-12
1190
Stephen Satava
RV-7
08-07
3102
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
07-22
4276
Kevin W. Bulla
Fokker Dr1
07-12
684
Peter McBain
RV-9A
06-06
2326
Robert Lussow
RV-15
04-13
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-12
Brian Robinson
Xenos
03-20
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
Projects Uploaded: 1567
Logs Uploaded: 289361
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
