Previous Builder
Next Builder
Date: 06-13-2021
Number of Hours: 50.00
Short Description: VP-X and PPS Install
So, once again I have not been good about logging, as it's been a few hours here and a day there, but everything has been about going through every wire that touches the VP-X and verifying it is correct and has no issues. As expected I did discover some along the way, that all took time to correct. This was the big weekend though when I physically installed, connected and for the first time powered up the VP-X and PPS. And no errors found as I went through the Configurator software! I still need to hook up the real or test loads again to every single circuit and verify proper operation with the software in the VP-X. I also will need to configure the flaps and trim. However, this is a huge milestone towards completion, and I am now ready to purchase the Dynon SkyView system at Oshkosh this year!
PPS Mounted on Firewall
VP-X Mfg Info
VP-X installed and connected
Previous Builder
Next Builder
