Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  DOUG WEHRLY
  New Braunfels, TX - USA
Aircraft:
  Sling 2
Total Build Hours:
  705
Web Site:
  http://www.mykitlog.com/dwehrly/
Date:  12-31-2019
Number of Hours:  0.50
Short Description:  2 Leak tested static and pitot lines
I used a syringe to pressurize the pitot lines holding the airspeed indicator at 90 kts for 1 minute with no movement.
I then pulled a vacuum on the static lines with the syringe and watched the VSI jump to about 1500 ft/ and then settle down after the plunger was stil
The vacuum held the altimeter at 1080 ft and the airspeed to 70kts for a minute with no movement and then settle down after the plunger was still.
I then vented the static lines using the alternate source switch, and everything went back normal with altimeter returning to 820 ft (my home altitude.)
pitot line pressurized
static line vacuum
alternate static source vented
 Recent Builder Activity
Builder Project Date Hours
Adam Grosser
RV-7A
04-25
837
Andrey Piskarev
Highlander
04-25
3819
Jean Gosselin
RV6
04-25
2679
Peter McBain
RV-9A
04-25
2122
Bob Corriveau
RV-8
04-24
4168
Michael Smith
RV-7
04-24
696
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
04-23
2046
Michael Sausen
RV-10
04-22
1513
Chuck Bennett
Sonex-B Tri-Gear
04-21
1152
Johann
TSI
04-21
914
Mark Johnson
RV-10
04-20
490
Barry Wawrin
RV14A-QB
04-19
2379
Paul Minelga
Bearhawk
04-17
4222
Jim Novak
RV-8
04-14
3159
Darrel Watson
H-5
04-12
457
Peter Calley
Sling4
04-11
2305
Marlin Sander
RV-7A
04-10
5680
Sven Hollenbeck
RV-8
04-08
70
Wendell Engelien
RV-6A
04-04
2354
Mark Spedding
COZY MK IV
04-01
3463
John McGlynn
S-19
03-30
346
Des Howson
Sling 2 Taildragger
03-25
3606
Edward Beam
RV-14A
03-22
1304
Gary Smith
RV-10
03-22
2863
Jack Clark
RV-14A
03-22
604
Tony Batchelar
RV6
03-17
Alex KOLLEP
Sportsman 2+2
03-15
1656
James Chadwick
RV-7
03-14
748
JAMES TRAYNOR
VELOCITY- XLRG
03-11
2528
Andrew Duff
Nexus Mustang
03-09
2943
Projects Uploaded: 1550
Logs Uploaded: 284006
Copyright © 2001-2024 Matronics. All Rights Reserved. Privacy Policy.
