Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Chris King
  Fountain Valley, - USA
Aircraft:
  Fokker D.VII
Total Build Hours:
  2401
Web Site:
  http://www.mykitlog.com/Chris2001Kin/
Date:  01-18-2023
Number of Hours:  0.00
Short Description:  2/2 Static Thrust Test No. 2
So there are lots of rules of thumb and calculators on the internet. Another rule stated that the thrust to weight ratio should be at least 0.5 for flight. My T/W is about .35. A little further research (Wikipedia) shows that many, many aircraft fully loaded have a T/W ratio worse than me. So this rule seems a bit conservative. Basically I will not have an acrobatic airplane. Low and slow as expected. In summary I think the numbers are adding up acceptably now.
Yet another rule states that a good prop ratio of pitch to diameter is 0.5.
I am at 39/74 which equals .527. So I choose well for the new prop. Note the old prop was 44/80 = .55. You would think a good choice but it had too much inertia to turn easily. So this factor assumes that you have the horsepower to turn the prop.
 Recent Builder Activity
Builder Project Date Hours
Brad Kunkel
Zodiac CH 601 XLB
04-22
1077
JAMES TRAYNOR
VELOCITY- XLRG
04-22
2619
Charles Wright
RV-8
04-21
84
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-13
Jack Clark
RV-14A
04-12
1440
Robert Lussow
RV-15
04-12
Michael Freiherr von Maltzahn
RV-12is
04-04
497
Darrel Watson
H-5
03-23
914
Mark Johnson
RV-10
03-21
750
Brian Robinson
Xenos
03-20
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
03-11
2234
Jim Novak
RV-8
02-15
3649
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
James Chadwick
RV-7
02-01
1013
Peter McBain
RV-9A
01-23
2326
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
01-15
4206
Mark Spedding
COZY MK IV
01-14
3925
Randy Doughty
CH750 Cruzer
01-10
1001
Stephen Satava
RV-7
12-30
2967
Chuck Bennett
Sonex-B Tri-Gear
12-28
1399
Andrey Piskarev
Highlander
12-27
4497
Neil Rosoff
EX-3
12-26
1133
Richard Tice
RV 7
12-09
987
Doug Volkmer
RV-7
11-24
1250
Stephen Eastham
CH-601 HDS
11-17
564
Robert Chopin
RV-8
11-15
868
Mark Weitkamp
CX4
11-09
3047
Barry Wawrin
RV14A-QB
10-26
2562
Alex KOLLEP
Sportsman 2+2
10-13
1756
Projects Uploaded: 1564
Logs Uploaded: 288447
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
