Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Dennis Häggqvist
  Knivsta, - Sweden
Aircraft:
  Savannah S
Total Build Hours:
  892
Web Site:
  http://www.mykitlog.com/Skee/
Date:  11-20-2016
Number of Hours:  25.00
Short Description:  Flight and follow up.
First flight of the Aircraft has happenned and at the time of writing 2018 i have flewn 26 hours.
Video of first flight you can find here, https://youtu.be/PTojgcdBmio
First flight ended quickly when i blew the alternator fuse, that resulted to change into a bigger battery 18aH. a few flights after that i had som ECU issues that made me land without engine power twice safely at the base.
Ecu was replaced to Dual ECU in Belgium and now that works, after that i had a valve guide loosen, that was also fixed in Belgium.
I see that as a part of testing a new aircraft, since then i have done 20 hours flight,
Cruise speed is 74 knots, a few more knots wouldnt hurt.
Thank you and good bye.
 Recent Builder Activity
Builder Project Date Hours
Michael Sausen
RV-10
04-26
1531
Adam Grosser
RV-7A
04-25
837
Andrey Piskarev
Highlander
04-25
3819
Bob Corriveau
RV-8
04-25
4171
Jean Gosselin
RV6
04-25
2679
Peter McBain
RV-9A
04-25
2122
Michael Smith
RV-7
04-24
696
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
04-23
2046
Chuck Bennett
Sonex-B Tri-Gear
04-21
1152
Johann
TSI
04-21
914
Mark Johnson
RV-10
04-20
490
Barry Wawrin
RV14A-QB
04-19
2379
Paul Minelga
Bearhawk
04-17
4222
Jim Novak
RV-8
04-14
3159
Darrel Watson
H-5
04-12
457
Peter Calley
Sling4
04-11
2305
Marlin Sander
RV-7A
04-10
5680
Sven Hollenbeck
RV-8
04-08
70
Wendell Engelien
RV-6A
04-04
2354
Mark Spedding
COZY MK IV
04-01
3463
John McGlynn
S-19
03-30
346
Des Howson
Sling 2 Taildragger
03-25
3606
Edward Beam
RV-14A
03-22
1304
Gary Smith
RV-10
03-22
2863
Jack Clark
RV-14A
03-22
604
Tony Batchelar
RV6
03-17
Alex KOLLEP
Sportsman 2+2
03-15
1656
James Chadwick
RV-7
03-14
748
JAMES TRAYNOR
VELOCITY- XLRG
03-11
2528
Andrew Duff
Nexus Mustang
03-09
2943
Projects Uploaded: 1550
Logs Uploaded: 284008
Copyright © 2001-2024 Matronics. All Rights Reserved. Privacy Policy.
