Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Don Patrick
  Oshawa, ON - Canada
Aircraft:
  RV-8
Total Build Hours:
  864
Web Site:
  http://www.mykitlog.com/Don Patrick/
Date:  12-30-2018
Number of Hours:  0.50
Short Description:  First flight
The weather has been spotty over the holidays and fighting the flu since Christmas Day didn’t help with getting into the air.
I finally had a break today. Winds were out of the west, light and variable, ceiling was overcast at 3800 ft, temperature was -2 degrees Celsius, and the runways were finally cleared of snow. The taxi ways, not so. I had no fans watching…didn’t want any distractions. My wife didn’t know until I was holding short for take-off!
I strapped in, turned on the Gopros and started my checks. Engine came alive after 2 swings and I got settled in. Eventually taxied to the main apron where I found a small patch of asphalt to do my run up. Everything looked good.
I was nervous. I had rehearsed this flight in my head over and over. Had fields picked out in the event I lost the engine. Played emergencies over and over. Clearance for takeoff was given after a 172 touched down.
I lined up, applied the power and got down to business. The 8 quickly accelerated and the tail became responsive in no time. Before I knew it, I was in the air. Straight out to 1000 ft AGL, turned the boost pump off, checked the fuel pressure, and turned left for 3000 ft.
I immediately detected a heavy right wing. Temps and pressures were all good. Unfortunately, I had the D180 screaming stall the entire flight. I was playing with the stall AOA calibration on the ground…have to fix that.
I did some air work and took in the view. Still couldn’t believe I built this in my single car garage! I could feel the draft coming from the rear canopy like many others report.
Decided to bring it back in. Called the tower ad they cleared my in for a 4 mile final. I requested a left hand pattern for the first landing and they approved. Checks done, base turn 90 mph 20 flap, final 80 mph, full flap, and brought it in.
Put it on the mains and let the tail come down slowly. Didn’t feel the wheels touch…maybe my heart was pounding to fast! Only 30 minutes for this flight.
Incredible experience!
My 8 has the following:
Airborne
Heading out
Post first flight
 Recent Builder Activity
Builder Project Date Hours
Michael Freiherr von Maltzahn
RV-12is
11-09
592
Brad Kunkel
Zodiac CH 601 XLB
11-07
1294
Jacob Hedberg
S-21 Outbound
11-05
Jean Gosselin
RV6
11-04
2802
Jack Clark
RV-14A
11-02
1632
Jim Novak
RV-8
11-01
3755
Daniel Goudreault
FP-303
10-22
108
Doug Volkmer
RV-7
10-21
1251
Charles Wright
RV-8
10-15
172
Mark Johnson
RV-10
10-02
777
Des Howson
Sling 2 Taildragger
09-25
3952
JAMES TRAYNOR
VELOCITY- XLRG
09-23
2693
James Chadwick
RV-7
09-19
1123
Mark Santangelo
DR-107
09-18
532
Mark Spedding
COZY MK IV
09-14
3993
Darrel Watson
H-5
08-26
970
Keith Borgstrom
Sonex
08-16
538
Neil Rosoff
EX-3
08-12
1190
Stephen Satava
RV-7
08-07
3102
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
07-22
4276
Kevin W. Bulla
Fokker Dr1
07-12
684
Chuck Bennett
Sonex-B Tri-Gear
06-13
1494
Peter McBain
RV-9A
06-06
2326
Mark Jackson
RV-8
05-17
1674
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-13
Robert Lussow
RV-15
04-12
Brian Robinson
Xenos
03-20
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
03-11
2234
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
Projects Uploaded: 1567
Logs Uploaded: 289277
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
