Previous Builder
Next Builder
Date: 06-04-2016
Number of Hours: 4.00
Short Description: Seat belts and panel wiring
I inspected the panel wiring on the pilots side and noted several wires that needed to be grouped together and zip tied. Also noted the throttle control rod was near some instrument wiring. I secured the throttle control to the air frame, rerouted some of the wiring, zip tied wiring and placed protective plastic wrap around some of the control rods. Also the seat belts require installation of a bushing in the seat belt end to allow the seat belts to rotate when they are secured in their position. These bushings are made from 3/8 aluminum rod cut to length and cleaned up. The front and rear seat bushings were created and installed in the seat belt ends.
Rear seat belts
Previous Builder
Next Builder
