Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Christopher Pryce
  Vacaville, CA - US
Aircraft:
  KR2S
Total Build Hours:
  1601
Web Site:
  http://www.mykitlog.com/vr6chris/
Date:  11-11-2020
Number of Hours:  14.00
Short Description:  Finished!
11/3 3
Registered ELT
Submitted forms for inspection
Looked over plane with friends for discrepancies
Securing more wiring
Fixed noted discrepancies
ELT test C/W, next due Feb 3
11/4 1
Installed fabric for foot area
Hardware cleanup
Cleaned out interior
11/7 4
Installed new oil drain plug and Safety wired
Adjusted control sticks
Replaced engine oil
Redid all oil fittings with EZ lube
Cleaned out interior again
Set engine timing to 28 degrees
11/8 2
Made new dipstick with proper level lines
Added inline fuse to starter switch
Test ran engine. Full static rpm is 2840
Fried AFR gauge with radio transmission
11/10 2
Transponder test completed
Installed new AFR guage. No interference with radio noted
Have to relocate transponder antenna. It is setting off the ELT
11/11 2
Reloctaed transponder anntenna
Finished new AFR Install
Verified prop bolt torque
Drained/cleaned/safetied gascolator
 Recent Builder Activity
Builder Project Date Hours
Brad Kunkel
Zodiac CH 601 XLB
09-08
1226
Charles Wright
RV-8
09-06
164
JAMES TRAYNOR
VELOCITY- XLRG
09-06
2680
Darrel Watson
H-5
08-26
970
Jack Clark
RV-14A
08-26
1554
Jim Novak
RV-8
08-24
3715
Mark Johnson
RV-10
08-22
765
Jacob Hedberg
S-21 Outbound
08-19
Keith Borgstrom
Sonex
08-16
538
Mark Santangelo
DR-107
08-16
527
Michael Freiherr von Maltzahn
RV-12is
08-16
555
Neil Rosoff
EX-3
08-12
1190
Stephen Satava
RV-7
08-07
3102
Des Howson
Sling 2 Taildragger
07-23
3900
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
07-22
4276
Kevin W. Bulla
Fokker Dr1
07-12
684
Peter McBain
RV-9A
06-06
2326
Mark Jackson
RV-8
05-17
1674
Robert Lussow
RV-15
04-13
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-12
Brian Robinson
Xenos
03-20
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
03-11
2234
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
James Chadwick
RV-7
02-01
1013
Robert Chopin
RV-8
01-19
930
Mark Spedding
COZY MK IV
01-14
3925
Chuck Bennett
Sonex-B Tri-Gear
01-10
1402
Randy Doughty
CH750 Cruzer
01-10
1001
Andrey Piskarev
Highlander
12-27
4497
Projects Uploaded: 1566
Logs Uploaded: 289037
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
