Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  James Anderson
  Sandy Springs, GA - USA
Aircraft:
  Larcair ES
Total Build Hours:
  3449
Web Site:
  http://www.mykitlog.com/jimanderson/
Date:  11-12-2022
Number of Hours:  12.00
Short Description:  Ailerons and flaps
Over the past three or four days, I've been rigging the ailerons and mounting the flaps. Flaps were relatively simple, except that I had to re-make the flap actuator rods, as my measurements from several years ago were about 1/2 inch too short. On top of that, I was unaware that there was an interference between the right actuator rod and the wing, so when I lowered the flaps using the flap motor, the right actuator hung up for a second, and bent the rod end. So now I have to make another rod. That's not a big deal, except for the time waiting on a new rod end. Yesterday I fitted the RAC flap position sensor to the flap torque tube. Sounds simple, but as usual, it took a couple of hours to get it right.
Aileron rigging is another story. Lots of skinned and bruised hands and wrists working in the small access holes. Note to self: If I ever do this again, make the holes bigger! There were a couple of bolts in the control rod/idler/bellcrank systems which demanded an unbelievable amount of time just to insert. I'm not through yet, but am getting pretty close.
 Recent Builder Activity
Builder Project Date Hours
Brad Kunkel
Zodiac CH 601 XLB
10-19
1275
Michael Freiherr von Maltzahn
RV-12is
10-17
575
Charles Wright
RV-8
10-15
172
Jim Novak
RV-8
10-06
3738
Jack Clark
RV-14A
10-03
1606
Mark Johnson
RV-10
10-02
777
Jacob Hedberg
S-21 Outbound
10-01
Des Howson
Sling 2 Taildragger
09-25
3952
JAMES TRAYNOR
VELOCITY- XLRG
09-23
2693
James Chadwick
RV-7
09-19
1123
Mark Santangelo
DR-107
09-18
532
Mark Spedding
COZY MK IV
09-14
3993
Darrel Watson
H-5
08-26
970
Keith Borgstrom
Sonex
08-16
538
Neil Rosoff
EX-3
08-12
1190
Stephen Satava
RV-7
08-07
3102
Daniel Goudreault
FP-303
08-02
80
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
07-22
4276
Kevin W. Bulla
Fokker Dr1
07-12
684
Peter McBain
RV-9A
06-06
2326
Chuck Bennett
Sonex-B Tri-Gear
05-31
1491
Mark Jackson
RV-8
05-17
1674
Robert Lussow
RV-15
04-13
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-12
Brian Robinson
Xenos
03-20
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
03-11
2234
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
Robert Chopin
RV-8
01-19
930
Randy Doughty
CH750 Cruzer
01-10
1001
Projects Uploaded: 1567
Logs Uploaded: 289220
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
