Zenith CruZer & Sonex Logs
750 Cruzer
n/a
Install cowl with clecos
Re-fit and re-measured cowl yet again. Was finally happy with overall placement, openeins, and prop hub clearance.
Drilled thru the cowl and into the fuselage/firewall metal. Cleaco'd in place. Man, this thing is rock-solid.
Still have to instasll nutplates and cut the opening for the oil inspection door.
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
