Brief Description: Part 2: Carb heat cable installation
See Part 1 for start of the day.
This was pretty straight forward, but had some rework to install different clamps and hardware.
Trimmed the heat cable to length, then used two clamps to secure it at the carb heat box. One end was to the adjustable pivot that opens and closes the carb heat air door, and the other just secures the cable housing to the box housing.
Secured the cable to the engine mount using two adel clamps on each tube of the engine mount.
