Zenith CruZer & Sonex Logs
750 Cruzer
03 - Wings
1-5-2023
n/a
misc prep for wing install
No pics.
Filed ends of wing strut fittings to fit landing gear and wing mounts. Still working on the outer wing brackets. Slow and tedious.
Measured angles of trailing edge to see if it would occlude against the fuselage.
Crimped spade lugs on the ground wire connections at the fuselage and inner wing.
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
