Mostly just fiddling around in the hangar. Some friends stopped by so that took some time. Nice day. Main task was that I trimmed an access port in the top side of the inner trailing edge. Since the trailing edge is the area that has the pitot-static lines, fuel lines, lighting and fuel sender wires, that area is impossible to reach once you install the wing. That is, unless you pull it out a bit. Other builders have started cutting this access, so I just followed along. I'll cut a replacement piece about 10mm larger all the way around and rivet that in place when everything is installed.
Changed out the dessicant crystals in my dehydrator setup.
Checked the fit of the upper/lower wing spar attach fittings. Some minor filing will be needed to allwo a smoother fit.
