Zenith CruZer & Sonex Logs
Date:  8-20-2022
Number of Hours:  1.30
Brief Description:  More cowl work
No picx.
Low progress on project today, but spent about 3 hrs at hangar.
Spent some time in the chapter 34 hangar to check on cleanup activities there. Then the group came down to my hangar to move the RV9A project from my hangar to the Chapter 34 hangar since I'll soon be needing more room in MY hangar.
Split the upper and lower cowl halves and began the process of installing nutplates to fasten the two halves together. Got one side drilled but then everyone said it was time for lunch, so that ended that!
Also moved teh Cruzer from one side of the hangar intot the middle where it should be. Cleaned up the hangar a bit, too.
