Zenith CruZer & Sonex Logs
Date:  5-16-2023
Number of Hours:  4.00
Manual Reference:  n/a
Brief Description:  Still more punchlist items
Checked additional aircraft items for model and serial numbers to include in POH.
Checked transponder wiring and breaker utilization. May have omitted or tied in with something else. Ordered new dedicated breaker.
Riveted the flaperon counterweights. Took awhile since my riveter sucks (disassemble after each rivet to remove old stem).
Installed cotter pins at the rudder.
Removed left side flaperon control stop; was allowing the control yoke to hit the right side of the center tunnel. Installed new stop that now provides desired clearance.
Figured out where I wanted to install inspection panels in each side of lower baggage compartment floors. Happy with result. Also fabricated L angle stiffener for underside of left panel. If I made ir previously, no idea where it is now@
