Zenith CruZer & Sonex Logs
Date:  5-15-2023
Number of Hours:  3.00
Manual Reference:  n/a
Brief Description:  more punchlist items
Painted remaining portions of 4 flaperon weights. Will install after a few days' drying.
Checked various equipment serial numbers and recorded for POH.
Applied N numbers
Removed hellhole cover that I installed prior to transport to KGKY. Checked inside; will have to reattach antenna cable; adhesive broke free.. Measured elevator cable tension. Roger at Zenith says to leave around 18 lbs against spec of 25 +/- 5. Loose cable helps resolve some binding issues others are having.
Studied ELT document. It expires in April 2024 (battery). Rats. $265 for a new one! I'll see if they have any deals at OSH in July.
Tightened the rod end jam nuts in the control rod area. Applied Torque Seal to provide indication of loosening in the future.
Cleaned the cockpit a little. Cleaned one section of the baggage compartment floor and temporarily installed to see where I'll need to install access covers for inspection.
