Brief Description: Work rudder cables; paint underside of left wing
Spent some time figuring out ho I was going to place the fairlings on the rudder cable outlets on the fuselage. The fairings don't allow much room to trim the lower edge and still have 10mm of room for a rivet spacing. The build lmanual pics show the factory had the same issue; it's obvious they have the rivet right on the bend that puffs out for the cable clearance. Will work this in more detail the next time I go there.
Real progress is that I painted the lower side of the left wing This turned outthe besto the 3 ing surfaces I've painted thus far. Amazing what happens when you set up the gun correctgly. I had previously read the HF manual thoroughly - several times. I finally consulted some YouTube tutorials on getting the gun set up correctly, and it's amazing how well things worked once I learned that detail I'm tempted to re-paint the upper side of the right wing, since that was the worst so far. But then I wanna get the wings installed, so...
