Zenith CruZer & Sonex Logs
Date:  6-8-2023
Number of Hours:  2.80
Manual Reference:  n/a
Brief Description:  Prep for weight and balance
Final push to prep for weight and balance, to be done tomorrow.
Attached a 1" adhesive square to antenna cable in the hellhole; earlier one was smaller and peeled off. Took a bit of writing to get the tab of the ziptie in the lock end. Cleaned with alcohol.
Cleaned hellhole areas; dusted, cleaned with cleaner-soaked rag. Vacuumed all crevasses.
Discovered I never terminated the ELT antenna cable with a BNC connection for the ELT itself. Checked my resources and spent some time on the phone with other chapter guys who said theyhad one. We'll see tomorrow.
Cleaned front areas post-window installation. Some plexi dust was coating the baggage area from finessing the window fit.
Installed upholstery, seats, extinguisher, ELT, etc in prep for weighing.
Measured prop-to-ground clearance.
