Zenith CruZer & Sonex Logs
Date:  5-16-2022
Number of Hours:  1.50
Manual Reference:  C75-FA9
Brief Description:  Install windshield
Pulled-back the protective film on the inside of the windshield. Cut the lower weatherstrip to size. Applied yellow weatherstrip adhesive to the channel and slipped it over the windshield. Had to tape in place in about 4 places because it was pulling away from the glass.
Using a helper, positioned the windshield in place on the fuselage.
Installed screws in the left and right side channel trim pieces, then positioned the upper "merge" trim piece over the upper window and upper windshield areas. Installed screws and rivted the upper window to the trim piece.
