Installed plugs; did not torque, but lightly tightened with wrench. Set up a termporary fuel feed using a milk jug and hose to the carb. Used 100LL.
Primed the oil galleries and pump. Squirted oil thru a bottle and hose into both holes in the oil filter adapter. After a few cranks, oil pressure began to register. Since it wasn't running, it was low, like 5 lbs.
Engine would not start. I believe it may be due to issues with the tach selection wiring that connects to the P lead wiring. Will remove the P leads and attempt another start.
