Zenith CruZer & Sonex Logs
Date:  3-21-2020
Manual Reference:  C75-NA-1
Brief Description:  Attach hinge for right side door
No pics.
Just a repeat of yesterday's tasks to install the hinge on the upper door frame. Included countersinking the hinge, trimming the upper frame, riveting the hinge to the frame and then riveting the other half to the upper door sill.
A lot of time spent finessing the hinge pin. Was VERY hard to insert and removed. Sanded and scotchbrited, then repeated again. Cut pin in two and bent the ends to creae the center-inserted pins.
