Zenith CruZer & Sonex Logs
Date: 6-25-2021
Number of Hours: 2.50
Manual Reference: n/a
Brief Description: Engine, brakes, avionics, misc
Lots of little piddling stuff here and there. And, yes, it's been almost a month since I've done anything on the plane. Not really, cuz there's been a few days where I went out and straightened up, etc.
Started off by lubing the gears and installing the SkyTec starter.
I then installted the PALnuts on the case halves-bolts. Previously torqued the nuts to the bolts, but never instsalled the PAL nuts.
I have only casually setup the EFIS communications in the past. A few weeks ago, pilot son was looking at the panel, and asked why the display was blinking regularly. Hmmm.... I played with it a bit here and theyre, but couldn't figure it out, so I wrote GRT avionics' tech support folks. Simple solution. I have an EFIS with a built=in GPS. I also have their Safe-Fly GPS and uAvionix ADSB subsystem, also with a GPS, since the EFIS GPS isn't a fine-enough resolution for ADSB. I had associated GPS2 with the SafeFly/uAvionix ADSB, since, duh, it was the second GPS.
Well, turns out in the setup screen, the GPS2 connection was supposed to be set to "No/Not Equipped." Works like a charm now.
Lastly, did the final trim and instasllation of the brake lines. Tightened all fittings. Got out the marine adhesive and glued the brake like retainers to the aft edges of the landing gear legs.
Lots of other parts searching, etc. as well. Found out that motor mount bushing washers I was sent are incorrect for my motor, so that was good that I found out.
