Brief Description: Misc Door stuff and a little panel work
Cleaned up the left door hinges and primed them.
Cut-off the threaded ends of two AN3-21 A bolts to make the door hinge pin.
Using the cut-off bolts as hinge pins, assemble the WO-1018-L Cabin Hinges to the WO-1019-L Door Hinges and assemble the WD-1018-R Cabin Hinges to the WD-1019-R Door Hinges
Recalculated where the access hole on the subpanel needs to be for the radio stack and marked the cut lines. I'll cut the panel during another session.
