Brief Description: Finished priming the Leading Edge parts and skins
As the subject says, I finished priming all the leading edge parts and skins. I top coated these with a white high temperature paint due to the HIDs. I figured that white will be good for light reflection and the high temp should resist the paint yellowing around the HIDs. I guess I could have left the rest of the skins in the green primer, but at least the white is a little more consistent (even though the coverage isn't quite as good at the opposite end from the HIDs).
