Bob Leffler's RV-10
RV-10
Riveting center section bulkhead
25-4, Steps 1,2,3,4,5,6, & 7
Cleco right and left mid seat rail supports together and rivet.
Cleco and rivet the nutplates of both mid seat rail supports.
Rivet the nutplates on the inboard flange of both center section bulkheads.
Bolt the mid seat rail support subassemblies to the center section bulkhead.
Rivet the stiffner angles to the center section bulkhead.
Insert snap bushings into the center section bulkheads,
Rivet the mid seat rail support assemblies to the center section bulkhead. (started, got about 25% done)
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
