Bob Leffler's RV-10
Date: 2-28-2009
Number of Hours: 4.00
Manual Reference: 25-2, 25-3
Brief Description: Started fuselage construction
25-2, Steps 1,2,3,4,5,6,7,8, & 9
Fabricated two F-1004N siffners from AA6-063x 3/4 x 3/4. Match drilled #30 holes between the stiffner angles and the center section bulkhead.
Cleco'd right and left mid seat rail supports. Match drilled #30 all holes in common with the seat rails and the center section bulkhead. Final drilled the #40 and #19 holes for the nutplates. Countersunk the holes for a #8 screw. Match drilled #12 holes on the seat rails and center section bulkhead.
25-3, Steps 1,2,3,4,5,6,7 & 8
Steps 1 and 3 were already done from Van's.
Final drilled the #12 hole in the upper flange of both the landing gear mounts and the center section bulkhead. Machine countersunk two holes to fit a #10 screw per the plans.
Enlarged the two holes on each bulkhead with a unibit to 3/4" for a snap bushing.
Deburred, roughed up with a scotchbrite, cleaned, and primed all parts. I've switched to NAPA 7220 self etching primer for the interior parts, since they will must likely will be top coated later.
Center section bulkhead
Parts all primed
