I started to sand the scoop until Janice arrived. She took over sanding the scoop. We didn't get it completed during this session. Janice will need to pick up during her next session.
I finsihed sanding the lower cowl with #400 and drilled out the holes that Janice accidnetly filled with epoxy.
I then applied some body icing underneath each window on both doors. There were too many curves that needed to be leveled out.
