Bob Leffler's RV-10
RV-10
OAT, Doors, Scoop, and Rudder
I dimpiled the access cover plate for the rudder.
I discovered that I forgot to drill the holes in both wings for the OAT probe. I drilled both holes.
I applied a little more body icing to one of the doors.
I finished rought sanding the scoop. All that is left is to give it another round of sanding with #400.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
