Zenith CruZer & Sonex Logs
Date: 9-5-2020
Number of Hours: 1.00
Manual Reference: n/a
Brief Description: continued panel work
First off, I discoverd that I forgot to include a spot for the backup battery on/off switch on the panel. I really hate to upset the symmetry of the panel, but upon investigation, I found a perfect spot for it no the upper edge of the panel next to the warning lights and magneto switches. Carefully marked the location, center punched it, and drilled. Looks pretty good.
Next, I mounted the GRT / uAvionics SkyFix GPS and ADS-B assembly on the outter side of the map box. I *think* it will be relatively easy to undo the 8-32 hardware holding it to the side of the box, and will allow easy access to the external ADS-B transmit antenna and the ADS-B GPS antenna, both of which are on that side of the plane.
Lastly, ran power to the GRT / uAvionix assembly, piggybacking to the EFIS power line.
