Brief Description: Paint upper surface of right wing
I cleaned and primed the upper wing surface the other day. Today, it warmed up juuuuust enough that I decided to try painting it. Interlux says it needs to be 50 or above; it was 52 when I started painting, and it was 53 when I finisihed.
Now I'll let it dry / cure for a week or so. The next possible painting weather shouild be on the 24th, 10-11 days away. I'll probably prep the left wing to clean and prime it in the meantime.
