Zenith CruZer & Sonex Logs
Date:  9-27-2019
Number of Hours:  1.00
Manual Reference:  C75-LA-2
Brief Description:  Correctly mount MLG leaf
Another helper arrived this AM; I decided overnight that I'd just elongate one notch a hair to see if that helped the fit.
@2 son and wife helped me remove the improperly-mounted gear. I ground it out a bit and we re-tried mounting it. Perfect!
Re-installed pads and lower angles and tightened retention bolts. All is well. Never did call Zenith
correct orientation
correct orientation
