Brief Description: Debur & Rivet door weatherstrip channel
Tedious but not difficult work today.
Removed the door sill weatherstrip channels (lower and aft). Deburred the channels and the fuselage surfaces to which they mate. Riveted both left and right assemblies.
The other day I had to enlarge the oblong hole in the left vertical channel to allow the fuel line to pass thru the hole with the grommet edging installed.
Today I removed the right aft vertical channel and enlarged that hole, then installed grommet edging.
