Crimped the wires back onto the connectors that came off the other day. Secure now. Attached right wing aft tip. Bundled loose wires ans used zipties to keep them from flopping around in the wing. There's a LOT of cleco's/rivets on each wingtip. I rough guessed probably 88 or so total.
Cleco'd right wing into place, then cleco'd left wng into place, also after attaching the wires and securing the bundle.
Then riveted all. Used "bulbous head" rivets to keep the regular rivets from pulling thru the thin plastic wingtips.
