Brief Description: Replace breaker / cut access hatches / close up
Worked in the hangar after Young Eagles rally today.
Replaced the XPNDR switch with a 3 amp breaker; This was to clarify the installation from the Garmin manual.
I had prevously measured and marked cutout holes for access hatches over the fuel sump connections under the baggage compartment. Drilled location of nutplates. Cut and drilled cover plates.
