Brief Description: Elevator paint prep / wiring cleanup
No pics.
As with the horizontal stabilizer, I cleaned the elevator, then scrubbed with dawn and a scotchbrite pad.
Masked the elevator hinge to prevent paint from clossing the holes. Masked the trim servo wire stanchions. Spray primed one side, then after drying sprayed the other side.
I've been conerned about space between two breakers, and had inserted a nylon spacer between the two breaksers. Secured it with a zip tie. Thought that might not be secure enough, so added a second zip tie and ensured both ties were very tight. Checked out continued operation after the repair.
