Zenith CruZer & Sonex Logs
Date:  5-9-2023
Number of Hours:  3.20
Manual Reference:  n/a
Brief Description:  Working punchlist items
Installed data plate after having it engraved.
replaced the left steering rod slide cover; old one got mangled during rudder rigging.
Snipped 2 rivet stems and ground down the burr after last week's riveting session.'
Drilled, test fit, and painted rudder stops. Still have to rivet.
After rigging flaperons, I encounted the typical binding when flaps were fully extended. I had to order two new AN5 bolts to provide extra length for a spacer washer. Removed old bolts, installed new bolts with washer between spacer and the vertical control rod bellcrank. Both sides. Works smoothly now.
Secured comm wires to the base of the Y stick.
Tightened elevator control cables.
Crimped cotter pins at nosegear axle.
