Brief Description: Safety wire engine parts / remove plexi paper cove
Added safety wire to engine oil filter, across the two front oil gallery plugs, and the engine oil temp plug and oil pressure regulator plunger cap.
Added a piece of rubber hose to the engine oil pressure sender line to provide protection from chafing against the baffling.
Removed protective paper and film from the inner and outer surfaces of both doors, the inner and outer surfaces of the skylight, and the front windshield film. Inner surface removed when windshield was installed.
