Brief Description: Door work / dessicant / windshield screws
Changed the dessicant crystals for the engine dehydrator.
Installed left and right door weatherstrips.
Removed each self tapping screw holding the windshield side trim in place, applied RTV silicone caulk, and reinstalled screws. Caulk allegedly keeps them from undoing.
Propped open the right door to the almost completely open position. Marked the location of the doorframe door lift pivot point, pilot drilled. Took 'em up to AS5 rivet size and riveted. Tried to close the door, and there was not enough stroke in the cylinder to allow door closure. Wrote to Zenith. See last picture below.
