Zenith CruZer & Sonex Logs
Date:  2-7-2023
Number of Hours:  1.30
Manual Reference:  C75-FA5
Brief Description:  Set wing dihedral and wing sweep
No pics.
Set up and measured with a plastic tape measure the distance from wing tip to center of vertical fin. Was even within 0.5", 12mm. This is within the allowable 50mm difference.
Next, continued to work on setting the dihedral. Very frustrating, more because of variances in digital angles. It's suppposed to be 1.4 deg on each wing. I was getting 1.4 on the R wing, but 2.3 on the left wing. Used some other digital levels and re-calibrated all of them. The values are now both 1.4 deg. Wing tip to floor is also consistent now as well. Next up is drilling the rear wing spar to the fuselage.
