Short time since I had to perform some Chapter duties in prep for our sheetmetal class.
Added more cleco's to the thick side gussets holding the horizontal stab in place.
Next, cleco'd the vertical stab in place (again) and called Tech at Zenith to see if the stiffeners at the bottom of the fin are supposed to go inside or external to the fin. Doesn't matter. I drew lines inside of the fin as a reference to place the L angles.
Drilled relief holes in the angles and cut notches to allow the aqngle to bend to conform to the curve of the horizontal stab leading edgfe.
