Zenith CruZer & Sonex Logs
Date:  10-21-2021
Number of Hours:  0.70
Manual Reference:  n/a
Brief Description:  mixture cable adjustments
No pics.
Stopped the other day after I threaded the mixture cable inner portion thru the drilled AN4 bolt that secures it to the mixture control arm on the carb.
I adjusted the cable housing and re-inserted the ball bearing to keep the cable control handle locked in the panel. After going back and forth quite a bit, it is obvious that I need to brace the cable at the carb just a bit more to keep the housing from moving around, peventing full lock-to-lock action of the cable.
