Zenith CruZer & Sonex Logs
Date:  10-8-2021
Number of Hours:  0.80
Manual Reference:  n/a
Brief Description:  Attach Carb
Had just a short time; frustrated I can't make more time to work on the airplane. Was in IS for 1.5 wks, so when I got back Ihad 4 dr appts, vet appt, tire appt, vehicle service appt, all in addition to normal time hogs like grocery etc.
So I had the chance, and I had the correct hardware that I rodered while in KS, so got to it. 4 nuts/washers to go on the intake manifold studs. No room. had to use gyrations to get the washers on the studs, then trying to move the nut into a flat position and get the threads started. 4 simple nuts. Took .8 hrs.
