Crimped termial ends to two lengths of 4 ga batter wire - one for negative post to fuselage ground connection, and one from the main solenoid to the postive battery post (did not connect to the post).
Finished wiring the fuel pump to the breaker (ran out of ring terminals the other day).
Connected just about all of the trim servo wires. A bit different on mine since I have a trim selector switch on the console to allow either the panel rocker switch or the stick grip buttons to control elevator pitch. Ran wires from the panel corner over to the switch and back. Then wired the servo indicator to the beldon cable heading back to the tail. Just have to wire the stick grimp wires to the toggle switch.
Mounted the headphone and mic jacks to the console center section. Checked for ground loops.
