Zenith CruZer & Sonex Logs
Date:  9-25-2020
Number of Hours:  1.50
Manual Reference:  n/a
Brief Description:  wiring cleanup
No pics.
Light work just straightening-up wiring harnesses to allow neat bundling later on. Installed magnetometer wires from fuslage to the EFIS DB25 connector so I guess this is the first fuselage to panel integration.
Separated and ran engine / FWF wires thru the firewall hole. Trying to figure out where to rivet a channel to support wires going to the firewall grounding block and 12V buss bar.
Copyright © 2001-2021 Matronics. All Rights Reserved.
